Icemanxxxv Posted December 27, 2017 Report Share Posted December 27, 2017 I built a Mod Crate Silo recently and have noticed that swapping cold atomizers between my dna 200 and 75c result in a different ohm reading between the two mods. The Dna200 wil read cold ohms at .154 and the 75c reads .176. the only real difference between the buildsis the 510 connector. The 200 has an evolve 510 and the 75c is sporting a FDV Black 510. Cold the difference in ohms be related to the 510 connections? The boards in the 75c is tight to the mod and no wiggle or corrosion. Should I adjust the mod resistance in escribe? or look more toward the build aspect of the mod? Link to comment Share on other sites More sharing options...
VapingBad Posted December 31, 2017 Report Share Posted December 31, 2017 Yes, the 510 can easily be even more resistance than that, my Silo is between 0.003 and 0.004 ohm mod res, one tip with these every six months give the board mount screws a tweak (loosen and tighten one turn) to keep a good electrical path for the ground. Link to comment Share on other sites More sharing options...
