Hernan Posted November 16, 2017 Report Posted November 16, 2017 I have finder DNA75, after update firmware2016-06-05, my second battery not work, just first battery... If i remove second battery and change to first battery still full, before update firmware my device not have a problem. Btw sorry my english not good, im indonesian Hope u can help... Thanks
retird Posted November 16, 2017 Report Posted November 16, 2017 You may have a bad connection in the battery sled wiring as the batteries are in parallel thus the connection of the sled for battery 1 is good but the connection is not for battery 2. The firmware for the 75 doesn't monitor each battery separately. If you take only 1 good battery and install it in battery sled 1 and all it good and then take the same battery and plug it in battery sled 2 and it doesn't work then the issue is with the connections for battery sled 2..
Hernan Posted November 16, 2017 Author Report Posted November 16, 2017 But,before i update it's oke.. thanks for your answer i will check it.
retird Posted November 16, 2017 Report Posted November 16, 2017 Was this the update you installed? Should be the most recent recommended.... SetupES_1_2_SP5_2_ServicePack.exe
chrismel Posted November 23, 2017 Report Posted November 23, 2017 same to me second battery not work at Therion dna 75
