Vape Bullet Posted November 12, 2017 Report Posted November 12, 2017 (edited) Does anyone out their know how to change the settings in the escribe software from 3s lipo mode to dual 18650 battery mode on my starss player dna200 mod. I have a pair of efest 3000 mah 18650 batteries. I'm in need of step by step instructions on how to make these changes. Someone please help I need a vape. Edited November 12, 2017 by Vape Bullet
Wayneo Posted November 12, 2017 Report Posted November 12, 2017 Mod Tab. Battery section. Change cells from 3 to 2. Adjust Watt hours appropriately. For the MOD tab to appear - Options (menu bar) -> User Interface -> Manufacture
Vape Bullet Posted November 12, 2017 Author Report Posted November 12, 2017 (edited) What battery type do I select? And what do I type in for the cell soft cut off. Not sure what to type in the capacity/wh box. Edited November 12, 2017 by Vape Bullet
Wayneo Posted November 12, 2017 Report Posted November 12, 2017 On 11/12/2017 at 2:41 AM, Vape Bullet said: What battery type do I select? Expand Li Po, if 18650's. I have only heard of 1 person inquiring about LiFePo's. CSC 2.75 or higher, wherever you feel comfortable. Wh Capacity should be written on your cells, or use the built in calculator. Or search for your battery type curve and someone will have stated the watt hours they got/use.
Wayneo Posted November 12, 2017 Report Posted November 12, 2017 Efests - rewraps. Running Battery Analyzer on your cells will be accurate for curve and Wh's. 1
Vape Bullet Posted November 12, 2017 Author Report Posted November 12, 2017 Thank you sir you've been very helpful everything's been set.
JardCrocker Posted November 15, 2017 Report Posted November 15, 2017 Hi...As per my knowledge the board was designed to be used with in a 3S config, starting with the DNA 200. The only reason we have the 133 and 167 option.People were fully aware of the output voltage limitation when in 2S mode.
Wayneo Posted November 15, 2017 Report Posted November 15, 2017 (edited) On 11/15/2017 at 4:39 PM, JardCrocker said: Hi...As per my knowledge the board was designed to be used with in a 3S config, starting with the DNA 200. The only reason we have the 133 and 167 option.People were fully aware of the output voltage limitation when in 2S mode. Expand You are correct, sir! But nowhere in this post was the 6.0 volt limitation ever mentioned. Perhaps it was meant for a different thread? And welcome Edited November 15, 2017 by Wayneo Welcome!!
