Does anyone out their know how to change the settings in the escribe software from 3s lipo mode to dual 18650 battery mode on my starss player dna200 mod. I have a pair of efest 3000 mah 18650 batteries. I'm in need of step by step instructions on how to make these changes. Someone please help I need a vape.
Edited by Vape Bullet
Mod Tab. Battery section. Change cells from 3 to 2. Adjust Watt hours appropriately.
For the MOD tab to appear - Options (menu bar) -> User Interface -> Manufacture
9 minutes ago, Vape Bullet said:
What battery type do I select?
Li Po, if 18650's. I have only heard of 1 person inquiring about LiFePo's.
CSC 2.75 or higher, wherever you feel comfortable.
Wh Capacity should be written on your cells, or use the built in calculator. Or search for your battery type curve and someone will have stated the watt hours they got/use.
Hi...As per my knowledge the board was designed to be used with in a 3S config, starting with the DNA 200. The only reason we have the 133 and 167 option.People were fully aware of the output voltage limitation when in 2S mode.
You are correct, sir! But nowhere in this post was the 6.0 volt limitation ever mentioned. Perhaps it was meant for a different thread? And welcome :hand_splayed:
Edited by Wayneo
Welcome!!
