Karl C Posted October 22, 2017 Report Posted October 22, 2017 An issue has occurred on my Therion BF DNA75 (original version). The Mod is jammed onto 75 watts, and it will not fire, nor can I adjust anything. Its not been used for a few months, so I don't know whats happened. Anything I can do in Escribe to solve this, or has the chip had it? Thanks in advance.
James Posted October 30, 2017 Report Posted October 30, 2017 Go into Device Monitor and see what it says for Buttons:. If it says Up, that means the Up button may be stuck down or something is causing it to read that way.
Karl C Posted October 30, 2017 Author Report Posted October 30, 2017 37 minutes ago, James said: Go into Device Monitor and see what it says for Buttons:. If it says Up, that means the Up button may be stuck down or something is causing it to read that way. Thanks, I'll give it a look. The buttons do all click perfectly tho. In the meantime, Ive replaced it with the colour model
VapingDad Posted December 16, 2017 Report Posted December 16, 2017 On 10/30/2017 at 1:34 PM, Karl C said: Thanks, I'll give it a look. The buttons do all click perfectly tho. In the meantime, Ive replaced it with the colour model Did it work if not connect it to your computer in escribe and memorize the battery stuff or screenshot it then factory reset it. Please do this at last resort because you will definitely loose everything
