koronis Posted October 7, 2017 Report Posted October 7, 2017 Curious if anyone else has seen this issue before, I have a Lost Vape Triade 250, I put 3 fully charged batteries in the mod and it's showing this in device monitor, checked the batts with a meter and tried another set and same thing. The mod won't even stay on unless plugged into USB also.
wykyd Posted October 7, 2017 Report Posted October 7, 2017 It's dead, needs to be sent back to evolv for repair. Comes from connecting to USB, I assume you either removed batteries while connected or one of the cells was loose. Had this happen with two 200 boards and most recent is a 250 board that has a new problem.
Abdul0786 Posted October 30, 2017 Report Posted October 30, 2017 Hope This might be hardware issue , when you put the batteries does it charges the battery ?? If it charges the battery then , remove the battery and charge it in external charger and try it.
koronis Posted October 30, 2017 Author Report Posted October 30, 2017 On 2017-10-07 at 5:54 PM, wykyd said: It's dead, needs to be sent back to evolv for repair. Comes from connecting to USB, I assume you either removed batteries while connected or one of the cells was loose. Had this happen with two 200 boards and most recent is a 250 board that has a new problem. Actually it wasn’t plugged in when it happened so not sure what caused it but it does appear to be an issue with the board, I’ll get in touch with support. 5 hours ago, Abdul0786 said: Hope This might be hardware issue , when you put the batteries does it charges the battery ?? If it charges the battery then , remove the battery and charge it in external charger and try it. It doesn’t appear to charge when plugged in, and it shows the same readings with fully charged batteries.
