Statistics Don't Reset
mstave
  On 9/20/2017 at 1:20 AM, James said:
Does the theme use Puffs -> Total, or Puffs -> Since Reset? This is a fairly common bug in themes.
Expand
I'll check, although I would've thought that the escribe stat reset would zero out that no matter what the theme used
OK, changed the setting to ->since reset - no change in behavior.  Reset stats from escribe - no change
Good thought though, and I thank you for the suggestion
Expand
Update - there are several settings that sort of look like each other - found another one that indicated count since reset, and that that one worked!
Thank again - you were right the first time
