Scornfulwolf13 Posted September 10, 2017 Report Posted September 10, 2017 I need help, I am completely new to DNA devices so I have no idea what I am doing with escribe. I wanted to try to look at it and stuff because my mod shortly flashes 69-71 watts before firing at the 120W that I have it set at when I push the fire button, so I wanted to see if there is a way to stop that, plus I wanted to see if there is a way I wanted to optimize how it reads my batteries, I saw some people talking about loading battery profiles ect. But it is all foreign to me so I need someone to help me out on where to start and what to do here. The batteries I use in it are a set of LG HG2s and a set of Samsung 25R(I think, I am not 100% sure on that set, I rewrapped them a while ago).
Wayneo Posted September 10, 2017 Report Posted September 10, 2017 1 hour ago, Scornfulwolf13 said: ... because my mod shortly flashes 69-71 watts before firing at the 120W The display shows live values. Absolutely normal while it's drawing current on it's way to your requested wattage. 1 hour ago, Scornfulwolf13 said: ... I wanted to see if there is a way I wanted to optimize how it reads my batteries Your batteries are always read perfectly fine. Only that little display might be wrong. You can either search for your battery type here and use someone elses results, with their (new/used) batteries, and their mod OR run your own by running 'battery analyzer'. By using 2 different mAh sets, it will only ever be right for the Wh's you choose (LG2's vs rewrapped 25R's). Cell soft cutoff is most important for you. 2.7-2.9V works well (based on what you feel comfortable with)
