The battery meter on my dna250 therion does not seem accurate. It goes about 90 percent down but then says check battery with still a little bar in the battery meter left. Is there any way I can match it so when the batterys wont go any lower the battery meter is also empty? I'm using 2 samsung 25rs and I downloaded the csv. Thanks.
It is just seeing some battery sag under load (it will start to lower the power output) it can be tired batteries or poor or dirty connections.  You could lower the battery capacity on the mod tab in Escribe by 10%, this only affects the metre it will not affect your vape or safety  (need to to set Options - User Interface to Manufacture to see the setting).
