Download your theme into theme designer, go to the "Screens" tab, select the screen you want to modify from the list of screens on the right. (Probably the main screen)
Left click on the wattage field that you want to change the increment of. Then from the fields on the right of the screen, find Source: Coil Power. Below that is a button labelled "Options"
Click that and an Options form pops up. There, change "Step Size" from 1 to 5.
Save your theme if necessary, then upload it onto the device.
Hope that helps
John
I’ve noticed something with watt increments but it could be just me.. new to evolv and escribe.
On default condition my increment is set to 1 and no decimal places so it changes 61, 62, 63 etc. I added a condition so if the wattage is equal to or less than 20 it will display 1 decimal place and change in increments of 5. If I start above 20 Watts and try to lower it, it goes 21, 20, 19.0, 18.0 etc. It will only start adjusting by .5 if I unselect and reselect after going below 20 Watts.
On the way up it works ok - 18.0, 19.0, 20.0, 20, 21 etc.
