Adri Posted June 24, 2017 Report Posted June 24, 2017 I just configured my new LostVape Therion 166 and changed the battery to Lithium Polymer with a capacity of 19.96 Wh, selecting 2-cell and loading a Sony VTC6 csv profile. I uploaded the new setting to the device and did a soft reboot. I charged both the VTC6 batteries in an external changer, but the Therion screen shows a battery charge of 80%. In EScribe device monitor it shows a capacity of 16.00 Wh, pack at 8.40 volts, both cells at 4.20 volts and change at 80%. Even though the batteries are 100%, the device still draws about 0.5 A current form the USB connector and trying to charge the batteries even more. If I disconnect the Therion 166, reconnect it and download the settings from the device, eScribe shows the correct battery parameters and profile, I uploaded previously. How can I get my Therion 166 to properly accept the new parameters or is my device defective?
retird Posted June 24, 2017 Report Posted June 24, 2017 You might reload the Lost Vape ^.ecig file with it's included csv file and see how that works with your fully charged batteries. You can then run Battery Analyzer yourself to get the csv that way... Here is the *.ecig file from Lost Vape in case you didn't save your original file before messing with the device... Therion166.ecig 1
Adri Posted June 24, 2017 Author Report Posted June 24, 2017 Hmmm... After sitting for a while and vaping a little, the battery indicator seems to have sorted itself out. It's showing the right Wh and % now on the screne and in eScribe device monitor.
Adri Posted June 24, 2017 Author Report Posted June 24, 2017 On 6/24/2017 at 9:25 PM, retird said: You might reload the Lost Vape ^.ecig file with it's included csv file and see how that works with your fully charged batteries. You can then run Battery Analyzer yourself to get the csv that way... Here is the *.ecig file from Lost Vape in case you didn't save your original file before messing with the device... Therion166.ecigFetching info... Expand Thanks, I already save the original settings before making any modification and also already had a copy from the forum saved. Seems the settings have automagically sorted themselves out.
TexNZ Posted June 29, 2017 Report Posted June 29, 2017 (edited) Having the same problem on my Therion as well. The problem seems to self correct then goes back to misrepresenting battery capacity rather sporadically. I'm removing batteries that are actually well charged at times -- then vaping using batteries that are actually low but reading high on the meter. Has your problem resolved completely? Thanks. Edited June 29, 2017 by TexNZ additional description
The_Vape_Weasel Posted June 30, 2017 Report Posted June 30, 2017 My Therion 166 be here tomorrow got the 25r file and went head and got the Lost Vape default while I was here thanks
