  On 6/19/2017 at 3:19 AM, Boomer35 said:
Thanks! I'm using a small 3d printed enclosure so would it be best to bridge the wires to reduce clutter and keep it clean? @Wayneo
You can, but the proper way to do it is to run separate wires for pins G 1 2 3 as to avoid voltage drop while firing due to tapping off the main power connections. Separate wires will ensure accurate readings.
  • Like 2
So I my G  port off my jst connector hooked into the bridge that connects my positive and negative? Or does it matter being that the 2 are bridged together to create the series connection? I have a couple different diagrams and one does it one way and this one is showing me different?
