Hi all. Ive just gotten my therion dna 75 mod . Im new to evolv chip and would like to ask the expert whats my next step to vape efficiently and maximize true potential of my mod? Im a noob on the escribe.
Straight 75, or 75 Color?
Go to file -> save as, and save a copy of the original configuration.
Check your mod is running the latest firmware.
Check out some YT video reviews
Battery analyzer really just gives you an accurate estimation of how much your batteries are charged/discharged. Your mod will fire perfectly fine leaving it at default.
IMHO the cell soft cutoff is very important. The 75 has a hard cutoff of 2.5V UNDER LOAD (sag). I and many others use 2.7-2.9v with the lower value giving you slightly more run time before 'Check battery' warnings. With a single cell 75, I value Amperage over mAh. In a dual or more cell, I'll go with high mAh.
I am using the dual Sony VTC 5. Specs are as below. Do advice me should i change the number of the cell soft cutoff?
  • Max. continuous discharge current: 20A
  • Nominal capacity: 2500 mAh
  • Nominal voltage: 3.6 V
  • Discharge end voltage: 2.5 V
  • Charging voltage: 4.20 +/- 0.05 V
  • Standard charging current: 1.25 A
If you're not gonna read, I'm not gonna type
8 hours ago, Wayneo said:
cell soft cutoff is very important. ..... use 2.7-2.9v with the lower value giving you slightly more run time before
