SiStA Posted June 13, 2017 Report Share Posted June 13, 2017 So, finally i became a happy owner of a DNA device. I purchased a Therion 166 and so far im pretty pleased with everything. But, (why theres always has to be a but...? xD) sometimes lately i deal with a weird problem. From times to times tc seems really underpowered. I vape normally around 200c to 230c and i get a really decent vapour production but then it seems out of a sudden pretty weak and i have to get it up to 250c-260c to get somewhat of the same vape. Where it gets even more weird is that that doesnt happen when i leave my setup overnight. Actually the first draws in the morning seem a bit overpowered too. So i thout that its probably my wicking that has more time to satutate overnight, since i use the infamous for leaking issues aromamizer supreme and i tend to use a bit more cotton than what i would use normally. But then again, until this happens and in wattage seems to wick just fine. My current setup if that helps somehow is a dual coil 316l ss fused clapton around 0.12Ω with power set at 120w and max hardness. Batteries are some new samsung 25Rs. From a little research i did online some people suggested in a similar problem that it has something to do with the internal resistance but unlike with what i expected my mod came with the ir setup in about 0.004Ω and I tried to measure it with the giz method after the excellent advice of wizzy (that i forgot to thank in the first place for his help) and I got somethimg very similar so i left it as it was. Also, i use the steam engine TCR for 316l. I cant provide any escribe data atm (no country for mac users...) but if you need something i will provide it as soon as i can. Any ideas guys or ladies out there ? Thanks in advance. Link to comment Share on other sites More sharing options...
MacVap Posted June 15, 2017 Report Share Posted June 15, 2017 (edited) I think you should read this (the most interesting part is starting at page two). Edit: Or maybe not, it's about 75C. Sorry. But the description is pretty similar. GL Edited June 15, 2017 by MacVap Link to comment Share on other sites More sharing options...
