I'm trying to change the display on my screen when in charging mode but nothing seems to be happening. I can change the Default Field screen but the Charging Field screen just mirrors the default screen.
You might have to wait about 60 seconds or so for it to change to the Charging Screens. First it has to exhaust whatever you have set in the "Active Time, and then also exhaust the "Idle Time" timers. By default the two together is about 66 seconds unless you changed one of them.
Thanks for the reply mikepetro. I've been having a play around with software so I restored the default settings but it's still refusing to change the charging field display. I've also noticed that I'm not getting the same live view in device monitor as the view shown in the simulator. I'm going to un-reinstall the software and see if that solves the issues.
I've un installed, re installed the escribe software but my board is still not showing the charge field options. I'm assuming that it's not the software because with the re installed software, when I click " connect and download settings" the downloaded settings from the board show the changed charge field settings but the board doesn't display them.
