Hi Is there any thing you have to do the first time you connect the battery because mine is giving me weak battery check battey warnings and the only way I can get it to charge is to remove the balance charger connector while the usb charger is connected and reconnect im using a turnigy 1000mah 11.1 v I haven't tryed to charge up the battery yet because of this Regards David
You may need to give it a little time to read the battery and it is worth putting the battery on a multi meter to check it's total voltage and the voltaged of the balance taps.  I have not got my board yet so these are just bits I have picked up reading the forum.
If the pack shipped with a cell out of balance, it will charge but it will likely charge very slowly.  Get a reading of the 3 cells from the EScribe device monitor and post them here.  We may need to walk you through a USB recovery charge.
