First time connecting the battery
David247
Hi Is there any thing you have to do the first time you connect the battery because mine is giving me weak battery check battey warnings and the only way I can get it to charge is to remove the balance charger connector while the usb charger is connected and reconnect im using a turnigy 1000mah 11.1 v I haven't tryed to charge up the battery yet because of this Regards David
You may need to give it a little time to read the battery and it is worth putting the battery on a multi meter to check it's total voltage and the voltaged of the balance taps.  I have not got my board yet so these are just bits I have picked up reading the forum.
If the pack shipped with a cell out of balance, it will charge but it will likely charge very slowly.  Get a reading of the 3 cells from the EScribe device monitor and post them here.  We may need to walk you through a USB recovery charge.
