laurie9300 Posted August 7, 2015 Author Report Share Posted August 7, 2015 LiPo noob here.........There seems to be no standard wire colours for the balance wires?I'm using a GensAce 1300 battery, of course the balance connector came pre-wired. This looks correct acording to the DNA datasheet, the pin numers/wire colours just look wrong. Please confirm for me this will be correct when I wire it up? Link to comment Share on other sites More sharing options...
KTMRider Posted August 7, 2015 Report Share Posted August 7, 2015 I would double check with a multimeter but it looks like red is ground and the 3 black is balance so you'd have to flip the connector. Link to comment Share on other sites More sharing options...
laurie9300 Posted August 7, 2015 Author Report Share Posted August 7, 2015 as it is (black GND) i get1. 3.82. 7.63. 11.5red as GND i get (plug flipped)1. -3.82. -7.63. -11.5 Link to comment Share on other sites More sharing options...
KTMRider Posted August 7, 2015 Report Share Posted August 7, 2015 The ground should be black as far as the connector is concerned and it looks like that's how the battery is wired. Not sure why they used only one red wire though. Link to comment Share on other sites More sharing options...
John Posted August 7, 2015 Report Share Posted August 7, 2015 Red and black wires are cheaper than colors, maybe? I've seen this before, and the picture is correct. In every pack I have ever seen with one red and the rest black, red would go to the tap labelled "3" Link to comment Share on other sites More sharing options...
laurie9300 Posted August 7, 2015 Author Report Share Posted August 7, 2015 Thanks guys, I feel better now! Link to comment Share on other sites More sharing options...
KTMRider Posted August 8, 2015 Report Share Posted August 8, 2015 I would ASSume that they would use black wire for ground and red wire for 1, 2, 3 (power). Link to comment Share on other sites More sharing options...
Guest Posted August 8, 2015 Report Share Posted August 8, 2015 I think it make sense, one red the rest black, it tells you where the first battery is in a series Link to comment Share on other sites More sharing options...
Nisei Posted August 9, 2015 Report Share Posted August 9, 2015 You mean the last Link to comment Share on other sites More sharing options...
Guest Posted August 9, 2015 Report Share Posted August 9, 2015 Yeah your right Link to comment Share on other sites More sharing options...
