Mpeterso1 Posted August 15, 2015 Author Report Share Posted August 15, 2015 Hello- has anyone else experienced a problem with the Ohms reading? Mine rises after firing it a couple times to 9.90 Ohms. Does it with every atty, even a tank I put on it. Tried loosening/tightening the connection. I loved it for the first 5 days, then Funtime was over. Anyone? Answers? So frustrating!!!!! I might just turn it in and ask for refund. Unfortunately. Thank you for your time! Mike Link to comment Share on other sites More sharing options...
turbocad6 Posted August 15, 2015 Report Share Posted August 15, 2015 might not be a bad idea to give a few more clues, like what kind of mod it is? sounds like a bad connection somewhere in the atty output circuit Link to comment Share on other sites More sharing options...
blueridgedog Posted August 15, 2015 Report Share Posted August 15, 2015 Did you build it? Can you post an image of the inside wiring, specifically the solder joint for the 510 OUT and GND as well as the solder job on the 510 pin? I suspect a cold solder joint in one of these locations. Link to comment Share on other sites More sharing options...
Mpeterso1 Posted August 15, 2015 Author Report Share Posted August 15, 2015 Geez-my bad. Its the Hana V200. Link to comment Share on other sites More sharing options...
turbocad6 Posted August 15, 2015 Report Share Posted August 15, 2015 hana v200's are known for potential 510 connection "issues", everything from poor wiring connection to poorly grounded 510 housings... if you are a tinkerer then open it up and inspect the wire to the 510, see if maybe the pin got stuck down, if everything looks good then try jumping from battery ground straight to your atomizer... if your not a tinkerer then send it back Link to comment Share on other sites More sharing options...
