Battery
2.2Ah pack at 20 will easily support the required amperage draw of the Chip.  It will work fine as a DNA power source.  The dimensions of the box is 103mm long by 52mm wide by 27mm tall.  The pack is listed as 103 x 33 x 24mm.  So with room for wires, I would say it is either a tight fit or won't fit.  The 52mm width would leave only 19mm for chip mounting and 510.
blueridgedog said:
I would look over this list:
https://docs.google.com/document/d/1t0WrumfRjWbN-UTHu5VUemZQHjkO5gqH9_rFbJa0wXk/edit?pli=1
I doubt you will find a 2.2Ah pack that will go in a b box.  You should reduced your desired Ah rating or go with a bigger box.
I fit 2200mAh batteries in the hammond B boxs.
Finished
https://instagram.com/p/6Yp84WAWEc
Basically the internals.
https://instagram.com/p/545cYQgWPy
xevape said:
[QUOTE=blueridgedog]I would look over this list:
Finished
https://instagram.com/p/545cYQgWPy[/QUOTE]
You're a facking genius, could you post pics of the internals of a finished build? I have the exact same components and I was wondering how in the hell did you do it.
That's what came on my max amps 2250 battery and I'm running 14 from the board to a male XT 30 connector and connecting that to the female end XT 30 on the 12 gauge wire of the battery and mine has been fine ......I don't think it can really be to big just as long as it's big enough
