Temperature control not working
bjmbonsignore
So I am 100% positive that my temperature control is enabled (see link #1) I am using the Hana Mod v200 (poor decision making skills) My temperature control has been working fine for the month or so that I've owned my dna200 but as of the past couple days it hasn't been working. I've also attached a picture of the graph (see link #2) while taking a puff, and it does not sense the temperature of the coil. Please help!!
Link #1 https://gyazo.com/9af4ab46b5f3a6cd07709a25dcb0223d
Link #2 https://gyazo.com/f5445af8b65fbc2082743b0639f2b74a
cold ohms at .55, looks to be in kanthal mode, a bad connection somewhere on the output to the 510, or 510 to atty, or atty to coil, assuming you really have a much lower ohm nickel coil in there? even if temp control is enabled it still auto senses and switches on the chip in use and right now doesn't look to be in temp mode which is most likely a bad connection
So I'm using Ni200, all connections inside seem to be fine. I'm going to try a different atomizer today, I've been using my Kanger SubTank Mini for the past 4 months or so and haven't had any issues with it before. Using the factory made OCC nickel coils, so I even tried ohm locking at .15 ohms. If this doesn't work I'm scrapping my hana v200 and ill use it for spare parts when my vtbox 200 comes in the mail!
