Chris_159 Posted August 17, 2015 Author Report Posted August 17, 2015 Do u you guys think I can fit a 103x33 24mm lipo in a Hammond 1590B enclosure with the DNA 200 board
laadam Posted August 17, 2015 Report Posted August 17, 2015 I think the hurdle would be fitting the 510. There's only 44.5mm to work with between lugs.I've attached the specs
Chris_159 Posted August 17, 2015 Author Report Posted August 17, 2015 laadam said:I think the hurdle would be fitting the 510. There's only 44.5mm to work with between lugs.I've attached the specs Thanks for the reply Can you recommend me a LiPo
laadam Posted August 17, 2015 Report Posted August 17, 2015 I have yet to build in the 1590B so I don't want to give you bad advice. There's a lot of information in this forum, in particular there's a running list of 3S LiPos that may help. Also, there's a member, xevape, that has posted some really nice builds using the 1590B. Good luck!
Chris_159 Posted August 17, 2015 Author Report Posted August 17, 2015 laadam said:I have yet to build in the 1590B so I don't want to give you bad advice. There's a lot of information in this forum, in particular there's a running list of 3S LiPos that may help. Also, there's a member, xevape, that has posted some really nice builds using the 1590B. Good luck! Thanks For The Help!!
Mikey Posted August 27, 2015 Report Posted August 27, 2015 If you can spring the extra money, go for one of the alpinetech CNC 1590b boxes. They are a little bit bigger and you'd be able to fit that battery with a little less worry. Still may have to shave a post off even with the CNC'd box.EDIT:Here are some tools that have helped me figure out what batteries to use. https://nonameboxmods.com/hect/hammond.html - gives you the sizes of all the hammond diecast boxes. http://www.hobbyking.com/hobbyking/store/lithium_polymer_battery_configuration.asp - and then you can select your dimensions on this and find batteries that will fit. Hobbyking doesn't have all the Lipos on the market, but they have a good number of them.
