thejoshdavis Posted August 27, 2015 Author Report Posted August 27, 2015 I got my Opus on Monday this week. It's been working great. Everything about the box and chip I love. About 5 minutes ago I pick it up and it fires for a split second and then dies. No lights on the board, no nothing. I tested the RDA on a Sig 150W TC and it fires up fine. I took the side door off to see if there was a major juice leak and the inside is spotless.Hopefully there is something I can do to fix this.
dwaindablane Posted August 27, 2015 Report Posted August 27, 2015 Sounds like the fuse, does the screen light up when connected to a computer using the USB?If so, check the fuse on the board by the balance charger socket. Here are other people with the exact same problem. https://forum.evolvapor.com/topic/68049-topic/
thejoshdavis Posted August 27, 2015 Author Report Posted August 27, 2015 It does not. The screen doesn't turn on when connected to USB at all. It doesn't turn on disconnected from USB either.
dwaindablane Posted August 27, 2015 Report Posted August 27, 2015 Hmm, I would raise a support ticket with Opus directly as it's not necessary a DNA200 chip issue.
Peter7734 Posted August 28, 2015 Report Posted August 28, 2015 Contact Roger cs@opusvapor.com Top bloke to deal with =)
