I just got my navy v200 from hana 2 days ago. In kanthal mode the resistance semms to read about .05 high and it jumps even higher when I vape. In temp mode the resistance reads about .08 high on my herakles ni200 coil and my sub tank nickel coil reads anywhere from .25 - .56 or even higher and it fries the coil. Haven't been able to contact Hana. What can I do to solve this issue myself.
Well u can get it exchanged or fixed by Hana or u can open the case and solder a ground wire from the ground tab on the board to the outer edge of the 510.....If you read around these forums you will see that the Hanas are plagued with this problem....They have Terrible grounding issues.....It seems they are not cleaning up the anodized portion of the case where the 510 and the screws attach to the board and case......u can usually fix it by doing what I said above......check the OUT wire from the board to the positive connection of the 510 as well because these are also known to be soldered poorly
