Noixd Posted September 1, 2015 Author Report Posted September 1, 2015 I charged my hanamodz v200 and the volts says 12.6 but the meter showed about 3/4 full. Still works but what could the problem be?
Noixd Posted September 1, 2015 Author Report Posted September 1, 2015 When I checked the battery on escribe all 3 cells were balanced and fully charged.
Noixd Posted September 2, 2015 Author Report Posted September 2, 2015 ok so i just let it charge overnight and the battery indicator and volts seemed to match up. But I noticed that the battery didn't last as long compared to previous session. Anybody know what I can do to fix this? Thanks
Noixd Posted September 2, 2015 Author Report Posted September 2, 2015 it also gave me a weak battery message at 10.9 volts.
Noixd Posted September 2, 2015 Author Report Posted September 2, 2015 attached are settingsdna200.zip
Brandon Posted September 2, 2015 Report Posted September 2, 2015 I would expect to see weak battery at about 10.9 resting voltage. Record the individual cell voltages while vaping at 100 watts and see if they are getting down to 3.09 under load. The Hana JST connector isn't doing you any favors either at that wattage.
Noixd Posted September 2, 2015 Author Report Posted September 2, 2015 the mod just shut off while vaping and plugging it back with the USB is unresponsive. First the opus and now the hanamodz. I have a vaporshark coming in and guessing that fuse will pop on that one too. I love the innovation with this chip but now I'm guessing it's issues with the chip not the mod manufacturers.
blueridgedog Posted September 6, 2015 Report Posted September 6, 2015 As to charging, I assume you set the WH rating of the pack. As to the chip, the issues seen with Hana and Opus have been install methods and materials in the majority of cases. There are some defective chips but they seem to be outweighed by incorrect installations.
