ricsuth Posted September 8, 2015 Author Report Posted September 8, 2015 Hi all, My self built mod has been working great for 6 weeks and then suddenly cut off. Display lights up when plugged in to USB and the charge symbol shows. Device monitor shows amps going to the battery but none of the cells are charging. When removed from USB I get nothing. Any ideas? Fuse looks good and I've checked all the wiring...?
ricsuth Posted September 8, 2015 Author Report Posted September 8, 2015 Would that happen mid-use? It died between firing, not plugged in. Replacing that fuse is going to be a ballache...!
ricsuth Posted September 9, 2015 Author Report Posted September 9, 2015 And the fuse does look intact...
VapingBad Posted September 9, 2015 Report Posted September 9, 2015 I would test the fuse with a multi meter to be sure.
ricsuth Posted September 9, 2015 Author Report Posted September 9, 2015 Will dig the multimeter out... cheers
ricsuth Posted September 14, 2015 Author Report Posted September 14, 2015 Fuse replaced, working like a charm now
