Tommo Posted September 30, 2015 Author Report Posted September 30, 2015 Hi. I have an Hcigar VT200 and have just noticed something. When using temperature control, about a second after my Vape, temperature protected will flash up and then a second later will flash up again and then a 3rd time. Is this normal?
Tommo Posted September 30, 2015 Author Report Posted September 30, 2015 Are these error flashes? And do temperature protect count as errors?
retird Posted September 30, 2015 Report Posted September 30, 2015 Not an error message but just telling you that the set temperature was reached.
Tommo Posted September 30, 2015 Author Report Posted September 30, 2015 OK thanks. Been reading manual and can set it to just display once
scoopy Posted October 1, 2015 Report Posted October 1, 2015 Uh can set I think to not display it at all....that's what I did
Tommo Posted October 2, 2015 Author Report Posted October 2, 2015 By setting the times to display to 0? Mine is set to 1 now and i'm happy with that. Still not sure that it is an error mind, mors status.
Mad Scientist Posted October 2, 2015 Report Posted October 2, 2015 Tommo said:By setting the times to display to 0? Mine is set to 1 now and i'm happy with that. Still not sure that it is an error mind, mors status. In the theme tab at the temp protected screen, use the drop down to select "show temperature" or "don't show."I agree that the default of a flashing message doesn't really make sense.
Tommo Posted October 2, 2015 Author Report Posted October 2, 2015 I want it to show when the temp is protected, just don't need it to keep showing it afterwards
