morpheusneo Posted October 5, 2015 Author Report Posted October 5, 2015 I've had a Hana V200 for about a week or so and I continually get the message about an unbalanced battery. I've left it plugged up to the on board charger through its cycle and it will charge to where one cell is about .2V lower than the rest. I've tried the selection in eScribe to ballance them, it gives me a message about reporting to evolv and then I don't notice any difference but leave it plugged in for hours just in case (I've read it does take a long time). Still after firing the mod just a few times the message starts appearing. Just wondering what I should do. Thanks for any and all help!
awsum140 Posted October 5, 2015 Report Posted October 5, 2015 Sounds like a bad cell in your battery. I'd contact the vendor or Hana.
scoopy Posted October 5, 2015 Report Posted October 5, 2015 I had this happening and it ended up being a little corrosion in between the solder pins of the balance port......being this is under warranty I don't know if you would wanna check but that was the case on mine although it never got that far out of whack.....It was just .03 off
