day two, battery stopped charging
Taver13
day two of having my board installed.  It charged fine yesterday.  today, i plug it in, and it does not charge, it connects fine to escribe, but the lightning bolt does not appear.  even connected to a wall adapter nothing.  i opened my mod up and checked all my ballance connections, and all of them appear to be in good order, any thoughts?
Double check all your solder connections again on the balance tap....that's usually the culprit......or clean them with alcohol on a q tip......With the battery off of course lol......I had a little corrosion in between them before I'm guessing from not cleaning the flux off after soldering and that caused me weird problem's. ....If u can't figure it out it wouldn't hurt to reflow all the solder points for the balance port........also check both sides of the board real close for missing or loose resistors
