Hooked it up to escribe, all cells reporting 4.1V which is expected, but the issue is when i try to fire the mod. cell 1 drops to 3.89, cell 2 drops to 3.59 and cell 3 drops to 3.66 so would i be thinking along the lines of a weak cell?
Maybe check the battery connections and the atomizer connections as well, as long as you're at it.  I'm not sure if the VTB uses connectors or is directly soldered, but either way a look-see can't hurt.
Its 2 weeks ish and the vendor has told me to go to the manufacturer. All connections inside look ok so must be a bad cell so time to look for a battery. Thanks for your help :)
