flem Posted October 10, 2015 Author Report Posted October 10, 2015 I get a great vape on this tank, but it seems at if I get liquid in my mouth when I take a Vape.Does anyone have this tank and use it on the evolv200?I have tried many settings, but still have that feeling of juice in my mouth and it is drinking juice like no other tank i have, but super great flavor, so I want it to work properlyI use the NI 025 coil at 260 degree and 40 wattany input would be greatly appreciatedthank you
Freshcut Posted October 10, 2015 Report Posted October 10, 2015 Try using your tank in another mod. Most of the time spitting is due to wicking.
flem Posted October 10, 2015 Author Report Posted October 10, 2015 Freshcut said:Try using your tank in another mod. Most of the time spitting is due to wicking. Hi Thank you. The starre pro only uses stock coils
Mikey Posted October 10, 2015 Report Posted October 10, 2015 Do you have the drip tip vacuum set to off? The on setting is for flooding your coil if you did not prime it, the off setting is for vaping. You likely have excess juice on the coil for it to spit at ya. If that's not it, then play with your temp, watts, and airflow till you find the sweet spot.
flem Posted October 10, 2015 Author Report Posted October 10, 2015 Mikey said:Do you have the drip tip vacuum set to off? The on setting is for flooding your coil if you did not prime it, the off setting is for vaping. You likely have excess juice on the coil for it to spit at ya. If that's not it, then play with your temp, watts, and airflow till you find the sweet spot. Hi Mikey.Yes everything is set on the faboulous starre pro as should be.I took your advice and played aroung with the settings and ended up with 230 degree and 40 watt and now I get a very delicious vape without drinking juice.The starre pro gives a great vape, but also uses a lot of juice.I am so glad that I finally spend some more money on a temp mod with the Evolv 200 chip, because somehow it gives a lot better vape to my tanks and RDAs than the other temp control Mods I have.Thank you very much
Mikey Posted October 11, 2015 Report Posted October 11, 2015 Glad you got it working well. Tanks on temp control have been hard for me to master, something always seems off. I might need to try lowering the temp that low as well.
Austin Green Posted October 17, 2015 Report Posted October 17, 2015 Hi Thank you. The starre pro only uses stock coilsExcept for it now has an optional RBA same as the crown, i own both of them...if it's spitting, sounds like too much power to me.
