lewisss Posted October 4, 2015 Author Report Posted October 4, 2015 Hi, I hope someone can help, I built my mod a week ago and everything was working perfectly, i have run all the production tests, battery analyser, and case analyser. everything was working perfectly until just now!I had the unit hooked up to escribe and it was great then as i took it off of the` mini usb i heard a 'pop'and the screen went blank.on inspection the fuse had blown.fortunately i ordered a spare fuse just in case when i ordered the board but before .replacing it i took the board off and visually inspected it to make sure there were no obvious signs of metal contactin metal where it shouldnt. i couldn't see any so replaced the fuse (not straight but good contact)plugged in the battery and 'pop' again fuse 2 down the drain!So did some continuity testing B- to B+ = open as expectedB+ to bottom of blown fuse = short as expectedB- to top of blown fuse =short not expected therefore when the fuse is intact the battery terminals are effectively shorted.I needn't have gone on but here are some other readings for informationB- to three ground = short as expectedB- to ground 501 output =short as expectedB- to +ve 501 output = Short, not expectedi cut off the 501 connector to check that was not a problem and it wasn'tB- is also shorted to outboard switch pins No 2,3,6 expectedand the three mounting hole pads. also expectedthe 4 conections for the balance port have no shorts between themselves, nor B+ and B-any ideas, or is the board shot?if so what do i do next?
xevape Posted October 20, 2015 Report Posted October 20, 2015 I had this issue on one of my boards which blew out my USB bus on my PC...If you were to plug it in did it effect your USB Bus or just blow the fuses?
