jcsfearless Posted October 25, 2015 Author Report Posted October 25, 2015 Hey everyone, I've got an hcigar vt200 and I'm running in to an issue. Also I tried searching but either I suck at searching or there is nothing in this subject. When I try to wake it up after it has gone to sleep it will fire. This happens after I lock the device, leave it alone long enough for it to sleep, then when I press the fire button it shows evolv dna 200 on the screen and will fire on the next fire button press. But after I let it go and try to fire again it will show that the device is locked. Is this a normal function or is this a bug or a setting I can change? From what I understand, the purpose of locking the device is to keep it from accidentally fire so this leads me to belive that it may be a bug.
lexalove Posted October 26, 2015 Report Posted October 26, 2015 definitely a bug. I'm sure the evolve guys will need to know the revision of Escribe and firmware you are running so maybe helpful if you also post that information.
jcsfearless Posted October 26, 2015 Author Report Posted October 26, 2015 Sorry about that.Escribe version 1.0.32Firmware 2015-08-21
lexalove Posted October 26, 2015 Report Posted October 26, 2015 I tested this on one of my DNA mods running the latest beta firmware and Escribe and the bug seems to be fixed because I can't replicate what you're describing.Go to this link and download /install the latest Escribe, I think it will fix your problem https://forum.evolvapor.com/topic/66731-topic/Opening post has latest Escribe at the top. After installation when you connect your device it will do an automatic firmware update to the required version.
jcsfearless Posted October 26, 2015 Author Report Posted October 26, 2015 I installed the 2015-09-30 firmware and it seems like it has fixed it. Thank you
