bnitch Posted October 28, 2015 Author Report Posted October 28, 2015 At first when I installed battery in Mod it kept giving me Too Hot error even though it was first vape. Then it stopped that but its telling me in device mgr that it's 97 f in the room and the board is 98.2. it's just about 72 in the room really. And yes I reloaded firm ware and installed results from case analyzer.
awsum140 Posted October 29, 2015 Report Posted October 29, 2015 Keep in mind the "room temperature" sensor is also on the board. Just handling it can cause it to read high. Now, add that it's inside an enclosure with limited ventilation and you can see the problem. Just the ambient heat generated by the board from vaping will cause it to rise. The best way to check it is to leave the mod alone, for an hour or more. Problem with that is it's DNA200 and works so well.
bnitch Posted October 29, 2015 Author Report Posted October 29, 2015 That temp was not after vaping been watching the news and having dinner. came back to room and that was the temp.
bnitch Posted October 29, 2015 Author Report Posted October 29, 2015 It just dropped 20 deg on room temp but still says board temp up at 96deg
bnitch Posted October 29, 2015 Author Report Posted October 29, 2015 I am rerunning case analyzer to see if I ended up with bad setting last time.
