Would it be possible to have the option of switching temperature readings to celcius? I know conversions and calculators are out there, some of us are just used to using Celsius.
Also, Would it be possible to change the display screen items based on a selected profile?
For example, my usual settings are based around the battery in normal useage, with the percentage, pack voltage and puff counter being used, but if i want to use a temp control build it would be great to be able to switch to a different profile and have the temp control setting on display.
You can simply change to Celcius by changing temperature and going down all the way to zero!
About the different screens - interesting idea but configuring it per profile would make escribe much more complicated to use. Maybe a better and simpler way would be to just have three more drop down fields in the screen tab for temperature / VW mode (next to the "default" and "charging" fields).
