ColonelPanicky Posted October 29, 2015 Author Report Posted October 29, 2015 I do apologise if this has been asked before, and I know it's known that HCigar's quoted 1300mah is incorrect and closer to 1000-1100mah. It's a real shame, if I'd known this before I got the device I probably would have got the Lost Vape Efusion, since the inside pics show that device is making really good use of internal space and rocking a genuine 1300mah battery.(Interestingly when I received my device, HCigar had pre-populated it with 12.21 WHr (e.g. 1100mah!!!)Looking inside the HCigar VT200 there does seem to be a fair bit of wasted space, with the battery 'shelves'/ battery securing protrusions etc.I was just wondering if anyone has replaced the VT200's default battery with one from another supplier, if so what was the maximum mah/ WHr battery you managed to squeeze in?- if you could provide a link that would be really helpful- I did have a look on hobbyking with the known dimensions of the battery, but couldn't see anything similar...Also, has anybody made any internal modifications to fit in a larger battery, how did this go, and what did you manage to fit in?Again apologies if this has cropped up quite a few times, but searching previous threads I couldn't see that there was a definitive answer to the above.Many Thanks!Joe
Xx3dge Posted November 4, 2015 Report Posted November 4, 2015 Someone must have some info and pictures?
sy5tem Posted November 10, 2015 Report Posted November 10, 2015 helloheres' a thread about this https://forum.evolvapor.com/topic/66435-topic/?do=findComment&comment=897339righ in these forums!
