p8ntballa9362 Posted November 6, 2015 Author Report Share Posted November 6, 2015 like i said i have the vapor shark dna 200 with the sharkskin on it. the test was in a 72 degree room, and the mod was standing up right so as not to be thrown off by a cold glass table. the results i got are as follows. these seem to be really high from others that ive seen at/ around 500+/-.cooling time constant : 3349.94sheating time constant : 1470.61sUSB charge temp rise: 7.25 F 11.31 F/Aand then obviously -20/110 Link to comment Share on other sites More sharing options...
p8ntballa9362 Posted November 6, 2015 Author Report Share Posted November 6, 2015 anybody? Link to comment Share on other sites More sharing options...
p8ntballa9362 Posted November 7, 2015 Author Report Share Posted November 7, 2015 bump Link to comment Share on other sites More sharing options...
swiftevo Posted November 7, 2015 Report Share Posted November 7, 2015 All the dna 200's I have seen, cooling time constant is 150-299. Something is very screwed up. Have you looked at the temps in device monitor to see if maybe something is up with the board temp or room temp reading? Are you on the latest firmware? Link to comment Share on other sites More sharing options...
p8ntballa9362 Posted November 7, 2015 Author Report Share Posted November 7, 2015 Yeah I just upgraded to the 9/30/15 or w/e. Did a manual download and install Link to comment Share on other sites More sharing options...
p8ntballa9362 Posted November 8, 2015 Author Report Share Posted November 8, 2015 Yup I'm using the very latest firmware. Manual download and update. You think it may be because of the shark skin? It is a decently thick silicone case Link to comment Share on other sites More sharing options...
Dampmaskin Posted November 8, 2015 Report Share Posted November 8, 2015 Could be. It's probably a good insulator. Try to run case analyzer without the skin, and then again with the skin. Compare the numbers. Link to comment Share on other sites More sharing options...
p8ntballa9362 Posted November 9, 2015 Author Report Share Posted November 9, 2015 new case analyzer results with out the shark skin.... still seems really high for some reason. can any one confirm or quell my concerns on this?cooling constant 877.17heating constant 2307.72usb charge delta temp 3.63f 19.13f/a Link to comment Share on other sites More sharing options...
kraze6548 Posted November 11, 2015 Report Share Posted November 11, 2015 the new values look alot better . i had issues running case analyzer the first time because the temp in the room was dropping way below the temp when i started . Link to comment Share on other sites More sharing options...
p8ntballa9362 Posted November 11, 2015 Author Report Share Posted November 11, 2015 you sir may have solved my problem... my ac works funny. it has a wide temp swing. if i have it set to 75 it will wait until it gets to 78+ to kick on then cool the apartment down to 70-72. and im sitting right under the vent when it kicks on. ill try running it when the ac is off. thanks. Link to comment Share on other sites More sharing options...
