Smoove0214 Posted August 27, 2015 Author Report Posted August 27, 2015 My opus 200 started saying ohms too high. I've been using the pre-built ni200 Crown coils with no problems.. I put a new coil in the base, that's when I noticed the mod had nothing on the display. If I plug it up to the usb charger the display comes on.. As soon as I unplug it, it cuts off again? Please help **I put my Arctic Tank with kanthal coils on the Opus and it's saying the same thing.. Ohms too high.. I just updated the firmware last night.. Haven't had any problems up till now..
scoopy Posted August 27, 2015 Report Posted August 27, 2015 Have u checked ur fuse to see if it looks blown? Opus has been having a lot of this going on .Check your ground and 510 connections...check your battery and balance connector
blueridgedog Posted August 27, 2015 Report Posted August 27, 2015 What is the battery reading? What is each cell showing in device monitor?
egeorge Posted November 20, 2015 Report Posted November 20, 2015 I am having the same problem with a VapeCige VTbox200 which is the white V2 model.It worked great for about 3 weeks, then died in the identical way as Smoove0214's. It will not come on unless plugged into USB, and it reports "Ohms too high" when I fire it (also while plugged in, it does not fire when disconnected). * I have checked the Fuse visually and with an Ohm reader. It looked ok (24ish, which I think is correct). * The Device monitor shows all three cells as good, voltage at 3.83 each, 11.49 overall.Any help would be great.
