obicom Posted November 21, 2015 Author Report Posted November 21, 2015 Hi folks, we working on a tube mod with 2 x 26650 batteries and a DNA200 chip. The problem is we cannot connect the plus from second battery to the balancer. I found out that we could use the DNA200 in "power supply" mode but without showing the battery status on the display. Do someone of you have a idea how we could solve this issue? Is it possible to connect the serial batteries with 7.4 volt to the balancer? An idea of a work around? Thank you in advance for any hint.
jurdanas Posted November 22, 2015 Report Posted November 22, 2015 2s and DNA200:https://forum.evolvapor.com/topic/66226-topic/
lewisss Posted November 23, 2015 Report Posted November 23, 2015 obicom said:Hi folks, we working on a tube mod with 2 x 26650 batteries and a DNA200 chip. The problem is we cannot connect the plus from second battery to the balancer. I found out that we could use the DNA200 in "power supply" mode but without showing the battery status on the display. Do someone of you have a idea how we could solve this issue? Is it possible to connect the serial batteries with 7.4 volt to the balancer? An idea of a work around? Thank you in advance for any hint.One way to do it would be to put a connector in the centre of the tube linked to the balance plug and insert one battery from the top and one battery from the bottom. Obviously this complicates things but it would only add the thickness of the connector to height of the mod
