SICAR187 Posted December 14, 2015 Author Report Posted December 14, 2015 Would it be possible to have the option under the "Baterry" for a 1-cell? For example a 66w 26650 : ) or even one 18650? Don't always need the 200w or 133w, but don't want to sacrifice the Escribe capabilities. Got then 66w by dividing 133w 2-cell option, maybe 75w would be better option?
Xx3dge Posted December 14, 2015 Report Posted December 14, 2015 Thedna200 is step down only so a single battery doesn't have enough voltage.
SICAR187 Posted December 14, 2015 Author Report Posted December 14, 2015 Xx3dge said:Thedna200 is step down only so a single battery doesn't have enough voltage. Thnx, I didn't know that...maybe this I'll be their new project.
Spector NS5 RD Posted December 14, 2015 Report Posted December 14, 2015 i'm thinking something close to the dna 40 board size and lay out, with the escribe capability. say 60-70 watts, 4.2 volt input, and buck boost topology. they'd def get another slice of the vape market. get on it guys, if yer not already.
Pathian Posted December 14, 2015 Report Posted December 14, 2015 Here's the original explanation of why the DNA200 won't work on a single cell.John said:The charger only steps voltage up. The board only steps voltage down, and the internal logic needs at least 5v to run. If you run from single cell, which is 3-4.2v, the charger will not be able to control charging, because it can put out a minimum of 4.5 volts. The board would only be able to put out 3v, and at any rate neither system would turn on. I'm not saying it isn't possible. I am saying this board can't do it. The reference design, with a 3s battery in it, is significantly smaller than a classic Hana, so you don't have to get particularly big to get the feature set. You can even turn the max power down and run a 3s battery that is smaller than an 18650 if you are so inclined. You just can't do it from a single cell with this particular board.
