The onboard temp sensor is stuck at 212f, so the board will not fire, i just get the too hot message. Everything else works well, able to create profiles and themes etc. I have opened a ticket with evolve, but does anyone know where the board temp sensor is so i can check for dry joints and shorts?
  I ran case analyser and a hard reboot to no avail so any help would be appreciated
Bob
  • 5 weeks later...
Board temp sensor..It looks like a little black barrel or graduation mortar board hat..on the outside edge of board about 15mm lower than your posertive power out on the same side of board as the buttons.. Coil temp is worked out by the chip measuring flucktuations in resistance.
