W124l29 Posted January 2, 2016 Author Report Posted January 2, 2016 Is my firmware bugged? My resistance sits at 0.08Ohms, and I've resorted to setting temperature to 550F just to get a taste of what should IMO read as 350F at the most. I've charged it fully, &c, left it off for hours, and it still hits TC limit immediately after my finger hits fire.
nismith8 Posted January 2, 2016 Report Posted January 2, 2016 What kind of wire are you using? Just because it says temp protected on the screen doesn't necessarily mean something is wrong. Just that the device thinks your coils are up to your set temperature and power is being throttled.
wwoyach Posted January 2, 2016 Report Posted January 2, 2016 mine is doing the same thing temp kicks in almost instantly ohms locked or unlocked worked once just fine after building and then 20 mins later when i picked it up to use it kicked in instantly
black lace Posted January 2, 2016 Report Posted January 2, 2016 ..Possibly a bad coil, or atty connection what is the set up? atty and coil details ? Simply no point in taking a stab in the dark :08 ohm & 350f could be anything on anything using anything.
