justchil Posted January 19, 2016 Author Report Posted January 19, 2016 I know there is a thread about showing TEMP instead of WATTAGE while in temp mode (or at least an option to).In addition (or alone) I would LOVE to see a third set of "fields" -- temp mode fields. These are generally my default settings. When I use a temp control atty I manually go in and change the default fields. Wouldn't it be great if there were default fields for when the device is using temp control?Make sense? Edit:Temp Field 1: WattageTemp Field 2: TempTemp Field 3: Last TempAssuming the Temp/Watt swap happens that is being requested by many.
Guest Posted January 19, 2016 Report Posted January 19, 2016 I think ramp up time to set temp would be cool
Gm111 Posted January 19, 2016 Report Posted January 19, 2016 This would definatly make it easier for some and maybe add a preheat adjustment via mod for those that want to change on the go or those that don't have access to a windows pc and don't want to deal with parallels, I know escribe is brilliant but being able to adjust everything we need to vape via the mod Is the future (preheat maybe just have the punch & time as standard, tcr, maybe having an atomiser analyser as a profile so you can build away from the pc)..
