Raito Posted September 24, 2015 Author Report Posted September 24, 2015 I know it's a clumsy question, but I used to connect these to unregulated box mods, and DNA chips is kinda new to me."If you look below the fire button you will see 4 small solder pads. Attach a 100 ohm resistor between the 2 pads on the left above the screen-printed 'F'. Resistor linkAbove the fire button, near the board edge and slightly off to the right, you will see 2 identical small solder pads. Attach your LED there, cathode side toward the middle of the board.That will give you what you want."the small solder pads are these two small circular parts ? just need a diagram because I can't imagine it, and what to do after that?!
vidalcris Posted September 25, 2015 Report Posted September 25, 2015 If you want to add external buttons, here is the info you need I hope you can connect the light directly to the OUT with the resistor btw !
Raito Posted September 25, 2015 Author Report Posted September 25, 2015 but that will illuminate the led when ever I fire, I want it to illuminate when ever the switch is on?
Mad Scientist Posted September 25, 2015 Report Posted September 25, 2015 Raito said:I know it's a clumsy question, but I used to connect these to unregulated box mods, and DNA chips is kinda new to me."If you look below the fire button you will see 4 small solder pads. Attach a 100 ohm resistor between the 2 pads on the left above the screen-printed 'F'. Resistor linkAbove the fire button, near the board edge and slightly off to the right, you will see 2 identical small solder pads. Attach your LED there, cathode side toward the middle of the board.That will give you what you want." the small solder pads are these two small circular parts ? just need a diagram because I can't imagine it, and what to do after that?!The small pads are below the fire button. The word "FIRE" is silk screened on the board. The pads for the resistor are to the left, above the "F" in "FIRE" just as the instructions indicate with the pads for the led to the right, just as the instructions indicate.It's hard to describe but if you look carefully at the board right where the word "FIRE" is silk screened, you will see them.
Raito Posted September 25, 2015 Author Report Posted September 25, 2015 yeah yeah above the F I saw them, I connect the resistor to the one toward the middle and to the "+" led and the other to the "-" and the other two like normal..... voila? right?it's 9 volts right?
Mad Scientist Posted September 25, 2015 Report Posted September 25, 2015 Raito said:yeah yeah above the F I saw them, I connect the resistor to the one toward the middle and to the "+" led and the other to the "-" and the other two like normal..... voila? right?it's 9 volts right? Since a 100 ohm resistor was specified if I remember right, I'm guessing closer to 3.3V. That would allow about 15mA forward current through the led, also factoring in the led voltage drop.
Raito Posted September 25, 2015 Author Report Posted September 25, 2015 does it matter what order I connect the switch to the DNA chip? *will just let me be more reckless*
