jslick_007 Posted January 31, 2016 Author Report Posted January 31, 2016 I seem to have a problem with low vapor production after about 100 hits or so, then poor vapor, temps exceed the set 450 and sky rocket, sometimes going as high as 800, but vapes like it's at 5w. Hard reboot fixes it, but it's not something one can do when you're out and about. Hope this gets fixed in a future FW update.
stuartro Posted February 1, 2016 Report Posted February 1, 2016 I had this once when the adjustable centre pin on my Griffin was loose, and at other times when screws on nickel coils had worked loose over time (likely due to expansion and contraction of the wire due to heating and cooling). Might be worth checking your build deck / coil for loose connections, check screws on coil are tight, etc. Hopefully it's that simple and not a hardware issue.
macz Posted February 1, 2016 Report Posted February 1, 2016 Check the 510 connector on the mod, broken adjustable spring could be cause of the problem
