Hi all, I am looking for a DNA200 BoxMod using the A123 LiFePo4 Batteries. Further Details can be found here: http://www.nkon.nl/rechargeable/26650/a123-systems-anr26650m1b-a-grade-3-3v-a-grade.html I searched the specs and searched the forum but didnt found the Information if those LiFePo4 batteries can be used & charged using the DNA200. My idea behind is to use 3 of them but not sure if this will work specially in case of charging. In regards to use those assuming it should work using an additional cable to connect to the tab Adapter isnt it ? Appreciate your confirmation.
I just found this Information: Q: What is the battery requirment? A: Battery needs to be a 3S LiPo/LiFePo4/IMR lithium type battery capable of handling a constant load of the max 23 amps. Having some overhead is always a good thing. So they should work :-) Thx Billw50
http://www.batteryspace.com/A123-System-Nanophosphate-LiFePO4-26650-Rechargeable-Cell-3.2V-2500-mAh.aspx I think you would get longer live out of the imr 26650 batteries but there again it depends how big you want you box to be http://www.batteryspace.com/lifepo4-a123-26650-battery-pack-12-8v-2500mah-32wh-70a-rate-rechargeable-battery-module-with-solder-tabs.aspx
Andrien said:
Thx Luguz75 I wasnt aware those INR are existing, amazing looks promising.
i was eyeballing these http://pages.ebay.com/link/?nav=item.view&alt=web&id=390876815792 but I think I'll just stick to my 1.3amp lipo pack it's a good pocket size for me. :-)
