cheeseborger Posted June 11, 2016 Author Report Posted June 11, 2016 I am just wondering if anyone has ran the case and battery analyzer on the duo using the lipo pack and what there results are?Currently I'm just using the file for the original efusion but i feel it might not be exactly the same due to size differences. The lipo settings are probably fine however.
VapingDragon Posted June 13, 2016 Report Posted June 13, 2016 After having every model of efusion now I'm assuming the duo came programed correctly. My first efusion was the original not long after they came out and I did need to load the file for it, my second was a regular efusion and it came preloaded with the correct settings, same with the mini I purchased. so at this point I am assuming my new duo's settings are correct.
cheeseborger Posted June 13, 2016 Author Report Posted June 13, 2016 Thanks I'll keep it the same then, just thought it was weird that the default case settings were so very different from the original efusion i guess.
Lethal Dose Posted June 13, 2016 Report Posted June 13, 2016 Can someone share the efusion dna 200 settings for the 1300 mah lipo? Because the efusion duo has the 2 18650 sled preinstalled so I found no default setting for the lipo. Should we go for the 14.43wh?
dwcraig1 Posted June 13, 2016 Report Posted June 13, 2016 14.43 wh is correct, be sure to set your cutoff for the lipo at 3.09 volts or higher.I suggest you save the CSV for the two cells.Here is a text file for "a" 1300 mah lipo, it will need to be saved as CSVIt is only going to affect battery gauge and battery % if it isn't dead on, I expect it to be just fine though.1300_mah_lipo.txt
