Yerakon Posted June 17, 2016 Author Report Posted June 17, 2016 Hi All, In some tests with escribe, under equal conditions, the temperature control appears at DNA75 Vs DNA200 with slightly different response. It seems that in the DNA75 the temperature line is more stable. It 'a different management due to the firmware?Both the graphics are made on equal terms and same settings (escribe) with the same atomizer (coil SS316L) and they were repeated with the same results with other devices.DNA75: DNA200: Thanks for your reply or your suggestions
VapingBad Posted June 17, 2016 Report Posted June 17, 2016 They work in the same way, although the 200 is more punchy. The 75 has some code in the fw to get smoother results with stainless steel which has a very low TCR and this will be coming to the 200 in a future firmware update.
Yerakon Posted June 21, 2016 Author Report Posted June 21, 2016 VapingBad said:(cut)in a future firmware update.Thank You VapingBad!
