Geodeathic Posted June 28, 2016 Author Report Posted June 28, 2016 I'm wondering about the functionality of the python script function. Are there examples any scripts people have written, or the kinds of things that you can do?I was wondering if it was possible to do stuff, like test a power boost function? For example, a script that, when firing, it increases the wattage level X% for X milliseconds, or starts high and ramps it down, for example starting with the power 50 percent and then turning it down .1% every 2 milliseconds until reaching baseline. Thanks for the responses everyone!
retird Posted June 28, 2016 Report Posted June 28, 2016 https://forum.evolvapor.com/topic/67057-topic/?do=findComment&comment=903632
Geodeathic Posted June 28, 2016 Author Report Posted June 28, 2016 retird said:https://forum.evolvapor.com/topic/67057-topic/?do=findComment&comment=903632 Yeah, I saw that before. I was more specifically interested if this was possible using the "ECig['Power Set']" variable, and if anyone else had actually tried writing python scripts, or if there was a repository of them. It seems like a pretty untapped function, and fairly simple. I may have to just look into seeing if I can figure it out or get some help on a python forum and report back.
retird Posted June 28, 2016 Report Posted June 28, 2016 You might just fill out a "Contact US" with Evolv and select Technical Support. Describe what you are wanting and ask that the request be given to James. He is the "guru" of the firmware.... I've not found any other Python Scripts but Good Luck...http://helpdesk.evolvapor.com/index.php?a=add
Geodeathic Posted July 1, 2016 Author Report Posted July 1, 2016 retird said:You might just fill out a "Contact US" with Evolv and select Technical Support. Describe what you are wanting and ask that the request be given to James. He is the "guru" of the firmware.... I've not found any other Python Scripts but Good Luck...http://helpdesk.evolvapor.com/index.php?a=addThank you! I appreciate the advice! I'll do just that, I'll share anything I learn here
