lewisss Posted July 6, 2016 Author Report Posted July 6, 2016 Hi, I have the dna75 chip and want to make a mod with 2 parallel batteries to get a better usage time. But with this brings up two issues. 1. Putting batteries in parallel keeps the voltage the same but doubles the current. So with this in mind do I need to increase the wire gauge for the battery connections? 2. Will it be safe to charge the dna75 batteries via USB considering they will not be balanced. Thanks in advance.
Spector NS5 RD Posted July 6, 2016 Report Posted July 6, 2016 No you will not need to increase the wire gauge when running a parallel setup. Just go by evolv's recommended wiring size. It will be perfectly safe to charge via USB. Will take twice the amount of time but safe. Balancing is not needed when using a parallel setup. The batteries will balance themselves do to them being in a parallel configuration.
HolmanGT Posted July 7, 2016 Report Posted July 7, 2016 ChunkyButt200 said:No you will not need to increase the wire gauge when running a parallel setup. Just go by evolv's recommended wiring size. It will be perfectly safe to charge via USB. Will take twice the amount of time but safe. Balancing is not needed when using a parallel setup. The batteries will balance themselves do to them being in a parallel configuration.Chunky,One caveat, the individual batteries should be checked to make sure the current charge of each battery is very close to to each other before placing them in parallel for the first time. After that process they will behave as one battery and no further checking is necessary and the batteries will balance themselves.
